Appologies in advanced. This bitrate lark does my nut in. So any help would be much appriciated!
I`ve got a film thats nearly 78 minutes long (4667 seconds) and the DVD2SVCD bitrate tab says upto 76 mins is one cd and over 76 is two cds.
Am I better off doing this as a 1 cd svcd?
And if so how can do I go about encoding it to a 1 disc SVCD?
Hm..ok
First question: If I were you, I'll go for 2 cds svcd. You're worst off with 1 cd svcd. With 78 minutes of mpeg2 encoded video and fit that on 80 minute cd will give you about 1100 kb/s, which is pretty crappy.
Second question: If you really want to fit the movie on 1 cd, then you just have to change the default minutes to whatever. (eg. like in your case, 76 to 78 minutes)
Hope that helps.
Slice off the beginning and end. that should save you the 2 mins.
The easist way to use the DVD2SVCD bitrate window is to enter the number of discs you want in ALL the windows, and set the size to whatever media you are using in ALL the windows.
This was you'll get the right number of discs/file size no matter what your runtime is. -
Thats interesting. I decided to do it 2x80mins cdrs. When it finished it gave me a 795mb bin and a 560mb bin!
Now if i say I`d like to use two 80min cdrs how come its not upping the bitrate so it uses the discs to their full capacity?
Instead I now have one disk with 1hour of video and 17 mins on the other! Its neigh on dvd quality, but surely it should raise the bitrate effectively, not waste 240mb? -
Hmm 60mins / 800 =13.3 mbs per minute
17min/600 = 35 mbs per minute!!
something a bit wrong there!
def something wrongCorned beef is now made to a higher standard than at any time in history.
it can - unless you relax restrictions, only go to the max of the svcd standard ..Originally Posted by Buggerlugs
So am I actually better off using a constant high bitrate and not variable at all if I want the bitrate to be used effectively?
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 23:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 00:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 22:03
