Hi there m8ies..
Are there any rocket scientists out there who can explain to me(in dull format) what the f**k Decimal point error means, when converting an avi file >> mpg(vcd) in TMPGEnc plus![]()
1> I have stripped the wav file using virtualdub 3c
2> I have used an original template
The prog converts for about 25 min then pops up the error![]()
Please any info will be well appreciated![]()
-- The Newbie GuidesIf TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Or try to convert the audio to wav before converting(If you have problems extracting the audio using Virtualdub try use AVI2WAV).
Or try to repair the AVI,DivX or the ASF.
Or try to use avidefreezer to fix your video source.Hello.
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 14:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 17:28 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
