I would like to batch process these
Any help is appriecated
CaT
Results 1 to 10 of 10
You need an audio file that is the length you wish to display the jpg for. You can create one in Gold Wave. Use TMPGEnc to load the jpg and video input, and the the audio file as audio input.
When you convert, you will have a mpg file that is a jpg that is displayed as long as you audio file is.Hello. -
tmpgenc or premier (using the maun concept encoder) or you can do it also with CCE or standalone MC making first a project file with tmpgenc ..
if it is not 1 jpeg per frame and you want each to display for a set time .. premier or Vegas video is a good bet .. -
Nero will burn .jpg's directly to SVCD. Just check the store as pictures option in the SVCD template. They will play on your DVD player,the next button will advance thru the pictures.
I don't think that TMPGEnc will batch encode them and when I try to just add jpg's with Nero I usually end up with pictures with bars. I haven't decided what is causing this. I have the Jpeg's saved 720x480 maybe I should be saving them 704x480. This is for a svcd.
I tried vcd easy to convert them but nero complains that they are the wrong format.. I have encoded them with Premiere and frame served to TMPGEnc. But I just thought this might be a faster way.
Tks
CaT -
wulf109
I guess I just really read your post. I haven't been checking store as pictures. Do you think that this would be causing this problem.
Tks
CaT -
Are you asking how to create a full motion MPEG from JPG, or just a slideshow (i.e. 1 jpg every few seconds)?
Impossible to see the future is. The Dark Side clouds everything... -
{*Doh!*}
Yer Quick!Impossible to see the future is. The Dark Side clouds everything...
How do I convert PDF to JPG?
By gary11364 in forum ComputerReplies: 34Last Post: 20th Jul 2017, 05:27 -
How to convert jpg pics to avi?
By pmolson in forum Video ConversionReplies: 24Last Post: 22nd Oct 2014, 17:50 -
VOB convert to jpg
By kevinguyen in forum Video ConversionReplies: 0Last Post: 10th Nov 2009, 16:49 -
Batch convert TIFF to JPG?
By Jeikobu in forum MacReplies: 9Last Post: 21st Sep 2009, 18:55 -
How do I convert PDF to JPG? Thanks in advance.
By gary11364 in forum ComputerReplies: 1Last Post: 12th Oct 2008, 11:08
