Since everyone is rusing to buy a SO-NY DRU500,
I wouldlike to find out how long does the recording
on CDR/W DVDR/W material went back ?
Some of my Blue CDR only last 4 years or less.
Maybe some one can set up a poll ?
Results 1 to 11 of 11
some disks last over 10 years for siure and more so this is going to be a really long poll ... plus dvd-r disks only been not that many years ..
At Meritline.com they sell BeAll (from Samsung) DVD-R discs that
are supposed to last a long time:
"LONG DATA LIFESPAN:
Samsung Certified DVD-R discs are archiving with a life expectancy of more than 100 years when stored at room temperature. If you need a DVD-R that you can trust for 100 years plus with your precious memories or important data, BeAll from SAMSUNG DVD-R is it! Used by several government organizations like NASA, SEC, FAA etc due to dependable, no-compromise level of quality. "
They are most likely doing accellerated aging tests on the stuff so
it's not perfectly accurate... But even if it lasts half of that it's good. -
50 years from now there will not be anything to play them back anyhow ..
maybe no power either .. -
LOL
Originally Posted by BJ_Mcheck out http://www.geocities.com/eatin_sammiches/sprucecreations.html to download additonal buttons and backgrounds for SPRUCE-UP menu creation -
I'm going to re-burn on much cheaper and more stable media in a few years anyway.Originally Posted by eatin sammiches for lunch
You think if I transfer all my pictures to cave paintings they will last longerOriginally Posted by BJ_M
I belive normal Cave painting does not retain quality as well as Digital Media. The Cave must be pretty Huge to retain the 5000 Jpeg My wife has.
yes but they last 5000 years ++ ---Originally Posted by SingSing
lets see how good your dvd is going to look 5000 years from now for a fair comparison ... -
Although cave paintings last a very long time they do suffer from quality loss caused by a variety of things such as humidity and occasional flooding. Not to mention over zelous archeologist and tourists.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 18:46 -
Philips DVDR 3330H recording codec
By yangp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 30th Jan 2008, 09:51 -
JVC DVDR/HDD DualPass recording system test... join in the fun!
By StuR in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Dec 2007, 10:05
