    Oct 2002
    Rochester, NY
    is it possible to add the extra features to a vcd from a divxx download? because most to the vcd i have burn just start right the movie right away. i would like to try to add the extras like trailers, audio setup. etcl...........
  2. Unless they are included in the movie you downloaded then no. They almost ceratianly will not be included in it as it would make the file larger than 750+mbs which is what most people want to stick too size wise. So they can burn it to a CDR.
    The electronic components of the power part adopted a lot of Rubycons.
  3. no... But you can add them to SVCDs
    (you can add menus and 1 Subtitle allthough)
