  1. I have a pioneer 104 and need a dvd rom that can copy DVD'S on the fly can any one help as i dont want to buy the wrong one
  2. Are these DVD's you have created, or store bought ones, ie films. If it is the latter this is not possible as they have to be ripped to remove encryption.
  3. Just like Movie VHS tape, you can't copy on the fly with two VCR.
    Use the 104 to rip, then burn into the DVD-R.
    You need a big harddrive, not a dvd-rom drive.
