i am using nero to make a svcd, the mpeg was encoded in the NTSCfilm, because it was 23.976 fps, template using TMPGEnc. when i drag the file in nero, it checks it and then brings up a message saying the file is invalde because it is not 29.97 fps. it asks me if i want to "turn off standard compliance and continue", "reencode the video file", or "cancel". what should i do?
thank u for the help
You should turn off standard compliance for mpeg encoded at 23.976 fps. All my SVCD are encoded at 23.976 fps and play just fine with APEX.
BTW, Did you apply 3:2 pulldown when you encode with TMPGenc? -
thanks for the help, and about the 3:2 pull down, when i converted i just followed the directions this site gave
Problem making chapters with RDR-HX780 Sony HDD recorder
By 1234567 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2010, 10:56 -
have a problem making multi-episode dvds??
By roboroach in forum SubtitleReplies: 0Last Post: 18th Dec 2008, 16:39 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 15:48 -
Problem making contact sheets from vids
By majax79 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jun 2008, 17:26 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03
