how can i add another layer of sound to a film.
If i have a film and i want to keep the original sound, but i also want to add some music over the original soundtrack..can i do this with tmpeg ??
ya of cuz you can...
If you have an MPEG with already one soundtrack on
Now, if you want a second layer... you're going to Multiplex again
file -> MPEG TOOLS -> MULTIPLEX (not simple multiplex)
-> ADD the MPEG file
-> add your 2nd MP3 layer
*** 2nd layer MUST be an MPEG-audio format... mp3 for example***
RUN and you have added a 2nd layerWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
I don't that is what he means El Torro. You are muxing in a second audio stream but they are not going to play both at once.
If you want to edit the audio of your original film (e.g., a VCD), you will first need the audio back as uncompressed WAV.
If you audio is in an MPEG video, then you can load the MPEG with VirtualDub and save the audio as WAV.
Then, load the WAV file with an audio editor like CoolEdit 2000. If you want to add additional music background, then load your new music audio and copy + paste/merge into your original audio.
Save the new WAV file.
If you need to put this back with the original MPEG video, then you will need to encode the audio back into MPEG-1 Layer 2 audio (or whatever the original format was in). Then, multiplex the new encoded audio with the original video with TMPGEnc.
Regards.Michael Tam
w: Morsels of Evidence
Menu background sound in multi avchd
By DODGEYONE in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2011, 13:13 -
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
Looking for Multi Track Sound Editing
By HoosierGuy in forum AudioReplies: 9Last Post: 4th Jun 2011, 21:58 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
