I am sick of my Pinnacle DC10+, so i'm looking for a new capture card, but there are tons out there. I just purchased a Hauppauge WinTV PVR 250 (Hardware MPEG2) and haven't had any luck in getting it to work, and also a AverTV Stereo (software MPEG2, hopefully AVI support also) but haven't tried that one much either. My price range is from 150US down, any suggestions? How are the cards I just picked up?
I want to be able to convert my hi8 tapes to MPEG2 to burn on DVD+/-R's. I have been really unimpressed with hardware MPEG2 cards so far when compared with capturing MJPEG and converting to DVD with Studio 8(I tried the Adaptec PCI Hardware MPEG2 card and it was terrible, plus none of the software really worked). So I'm not sure if i want a hardware MPEG2 card or a standard card that can do AVI's with a WDM & VFW driver for me to encode later with. (I'm checking out the Dazzle product line right now)
Specs:
AMD Athlon XP 2100+
512MB PC2700 DDR333
120GB WD 7200rpm HD
ATI Radeon 7500 64mb DDR
ECS K7S5A mobo
NO DAZZLE!!!!!!
If you think you had problems with the other cards, you ain't seen nothin' yet!
If you want the "practicle" best and easiest check out the Datavideo DAC-2. After that try the DAC-100, or Canopus ADVC-100, or ADVC-1394, or ADVC-50.
If price is no object, try the $2000.00+ solutions that Canopus offers.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Get the PVR-250 working, it will make the best looking mpeg-2 via hardware encoding. I have not seen any other hardware encoders that will beat the PVR-250, including the new Snazzi III.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
