I want something high quality that will look almost dvdquality on my computer should it be mpeg2 or divx. A secondary issue would be that it would fit on one cd, but the quality is most important
At a higher enough bitrate, both will look very good. Remember, if you rip from a DVD, the video will be in MPEG-2 already and if you are happy with huge files, this will be the best quality source (i.e., no further processing).
If your intention is to view the video on the PC and you want to fit a decent amount of video per CD, DivX is probably the better option.
Regards.Michael Tam
w: Morsels of Evidence -
keep in mind divx is more CPU intensive than (S)VCD, so if you multi-task alot or have a slower CPU, etc... you may wanna reconsider
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 13:00 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 10:24
