I have just purchased the WinTV FM (401) card, installed the drivers from the web, installed the app from the web & installed the FM app from the web. The Radio app is not that bad, the IR for the remote works fine, the Win2000 is not the greatest app at all but it works, but when I started up the VirtualDub & went to do a capture to try it out, the size was 320x240, it worked & the capture worked also. But when I tried to make the size bigger ( trying to capture at 640x480 or 480x480) it is not allowing me to change the size. Then i decided to install the BT drivers from Sonics website. That worked & once again I opened up VirtualDub and at 320x240 I see the preview video without any problems but when I go to change the size to anything higher then that it does not give me any errors but there is no video showing up ( the app acts like it is locked up but it is not ) the only way I can bring the video back is to change the res back to 320x240.
How can I change the res?
Also, when the BTdrivers are installed the remote is not working ( not that I care about it )
Can someone help me out please alittle with this card let me know how I can capture in higher resolution.
Thank you
"Computers are stupid, but they are capable of being stupid one million times per second"
This is normal. You cannot use overlay with any resolution higher than 320x240. I turn off the preview too (I couldn't even tell you if it works with it or not). Remember with the btwincap drivers, the hauppauge apps won't work anymore.Originally Posted by spooky
Mixing AVCHD with SD DV-AVI, frame size & arrangement question...
By sdsumike619 in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2012, 23:18 -
DVD aspect ratio & file size alters in video editing software
By Chrismar in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2011, 08:48 -
File Size & Video Bitrate Calculator
By wiseant in forum Video ConversionReplies: 3Last Post: 27th Nov 2009, 22:59 -
My new WinTV-HVR-1600 only shows B&W video
By gigantibyte in forum Capturing and VCRReplies: 24Last Post: 20th Jan 2008, 11:29 -
Ok, another question about video size
By geek2330 in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2007, 21:49
