If I set Tmpgenc:
Motion Search Precision to Normal
audio=224 kb/sec
Bit rate=2500 kb/sec
OTHER INFO::::
CBR
23.976
16:9 NTSC
352x240 Mpeg 1
Would I get a high quality VCD?
Standard Compliant?
Any other settings I should know of?
Ripped w/ Smart ripper and converted to .d2v and .wav with Dvd2avi
if you want a VCD, this are good setts... but it isn't necessary a GOOD quality image... cuz the RESOLUTION is too low... I suggest you make a SVCD... much higher resolution => better quality
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Also, a huge factor in the final quality of your encode is the quality of your source video. If you have a poor source, does'nt matter what settings you use you will get a poor output.
With the settings you state this will not be a standard compliant VCD, it will be an XVCD. Bitrate for VCD is set at 1150 kbps. -
yes, so we suggest you mke a SVCD => higher bitrate
Ya, of cuz, if your source has an awfull quality, your (S)VCD will be awfull tooWanne earn something a couple of dollars?
Gents,
Just my two cents worth. After making many coasters confirming to myself that resolution was not the driving factor for a quality repro, I can state that it is more dependent upon the bitrate used rather than the resolution. However, as ya'll have said many times over garbage in = more garbage out no matter what the resolution or bitrate. Yes, you can clean it up but it will still a a function of "multplicity." Let me explain how I can to this conclusion.
From the exact same AVI clip that was recorded at 480x480 (using Vdub 1.4.10 and Tmpgenc +), I made a true VCD compliant disk and compared that to an XVCD disk where the only difference was the bitrate was changed from 1150 to 1800. The difference IMHO was noticeable. With the nod going to the XVCD repro. To further complicate matters I made an xsvcd repro from the same AVI clip using the same 1800 bit rate and compared it to the XVCD. To my very untrained eye, I could not tell any difference. Even tho one was at 352.240 and the other was at 480x480.
Yes, yes, yes I know there are a multitude of other other parameters that influence the outcome. But I am taking them one at a time, so that I can actually see or not see what the influence of that parameter is on the outcome. However, in any case beauty is in the eye of the beholder and that is the real test. Thus, for me and what I am attempting to do is to capture at SVCD with enough bit rate to force the output to fit onto 2 cdrs and to my untrained eye that is good enough.
Is it DVD quality, a very emphatic NO. But for me that is OK.
Thanks for letting me get my two cents in.
Ed
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 09:21 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
TMPGEnc Authoring Works - bitrate too high
By ecc in forum Authoring (DVD)Replies: 9Last Post: 19th Feb 2009, 14:06 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
