I have a semi-stupid question. I've been fighting with trying to get all my movies/tv shows I've captured in VCD format onto a DVD. [Speaking of which, if anyone has a working link to download the DVD-VCD example/test file from this site, I'd appreciate it.] I'm hopefully going to get it to work this time. I was wondering what would be better quality: Re-Encoding an MPEG-1 file into an MPEG-2 file, perhaps raising the resolution, or taking the VCD playing it on my DVD player through the S-Video output [letting it do the interpolation] and recapturing it on my AverTV card at DVD resolution? It seems like a decent option, rather than having software try and raise it. Anybody have any ideas/suggestions?
thanks a lot.
- onewaydown -
ummmm... there is a guide for putting VCD on DVD-r. You could put multiple shows on that way. Raising the res won't gain you anything. Check Here and Doom9.org for the guide.
Well, it was kind of a 2-part question. I'm following the guide, again, hopefully with better luck as it's been updated slightly. But I was also wondering about 'DVD' resolution from a lower resolution. I was just thinking how it would look in comparison between resampling vs recapturing. I was just wondering so if I ever wanted to make an actual DVD without any minor/major problems like what could happen with a DVD-VCD.
thanks though.
- onewaydown - -
Honestly, neither would look any better ( probably worse ) than the original VCD mpg.
Just up the sound to 48 and place on a DVD. -
I think you misunderstand the point.
VCD video with 48khz sound IS DVD COMPLIANT. -
Right, but when I read the vcdhelp guide it mentions something about "the picture zooms in on a corner of the menu screen when browsing the DVD-VCD menus." I was thinking that if I changed it to an MPEG2 file, maybe even at 720 res, that it would just be easier/more compatible.VCD video with 48khz sound IS DVD COMPLIANT.
However, I think my main problem right now is my two dvd players don't really like my Phillips DVD+RWs. I have a Sony DVP-S300 and a Lasonic Delta-1000. They like my Imation DVD+Rs, but the Sony won't read the Phillips DVD+RW and the Lasonic keeps telling me it's an CD-DA disc. It works fine in PowerDVD though, so perhaps it will be fine once I get a better player, or maybe different discs.
Thanks for the help tho.
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Firewire capture - Encode on the fly?
By BruceLEET in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 18:45 -
DV Capture to WMV encode. Looking for some advice.
By silmarallion in forum Newbie / General discussionsReplies: 10Last Post: 19th Aug 2008, 18:02 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 05:29 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 12:03
