Closed Thread
  1. I've found a way to capture to vcd format in realtime
    that give very good results.
    The captured video have a very good quality,i think i tis
    even better than the video captured whith wintv pvr or Dazzle DVC II.
    This solution is software only,for the tests i have used a hollywood + card and a wintv whith cinax winvcr 2.0 for capture from a dvd.But there we must do some trick to the program to get this quality.
    If you like to now how is done, just reply to this post and i explain to you.
    You can test youself and share the results whith me.
    I think itīs really good considered we dīont use special and expensive hardware
    Maybe this is what you have waiting for...
    Jul 2001
    Certainly worth a lookie...
