I created an SVCD using Virtual Dub to extract the sound as a wav file, then TMPGEnc to encode, VCDEasy to create bin/cue files and finally Virtual Daemon and Nero to burn the discs. The discs play fine on my PC but in my DVD player the picture is fine but the sound is all stuttery and skips about, any ideas?
Thanks.
Seems as though your player has a few problems playing SVCDs, according to your fellow owners. You may want to try the VCD header trick to see if it will play your SVCDs that way.
Hello.
Sound is stuttering
By GeordieDave in forum Newbie / General discussionsReplies: 7Last Post: 19th Apr 2011, 18:21 -
Video stuttering.
By reyerd in forum Software PlayingReplies: 12Last Post: 27th Mar 2011, 05:07 -
Playback of DVD authored with multiple angles has stuttering sound
By kipling100 in forum Authoring (DVD)Replies: 2Last Post: 14th Nov 2009, 22:54 -
DVD stuttering
By Koron in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2008, 15:16 -
stuttering video
By g0dm0de in forum DVD & Blu-ray WritersReplies: 6Last Post: 29th Jun 2007, 12:13
