I created some masters a while back from some shows i produced on DVD-R .. I made them up with menu's etc. Each disc has two titles with one chapter each.
My clients have recently expressed interest in VHS versions of the same shows so I want to create some DVD-R masters without menus and some blank leader on the front and back.
I do not have the original m2v files anymore nor do I desire to rencode them. I would like to take the VOB's or demux to seperate m2v files each of the two Titles so i can rebuild them in my DVD authoring program. What is the best way to do this. SmartRipper will do it but puts both titles into one m2v that I then have to mux with the audio and split in the middle and demux. I am looking to cut this step out. Any suggestions?
Smartripper should be able to demux each title separately. I just used it to remove a single title from Beauty and the Beast and it worked fine. Use Stream Processing and just select one of the titles. Select Demux to File, save the selection and Start.
Splitting AC3 48Hz 2 Channel into 2 seperate files
By Caliburner9 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jan 2011, 23:51 -
Splitting AC3 Into Seperate Files
By travelagent73 in forum AudioReplies: 4Last Post: 19th Aug 2009, 14:46 -
copy to from dv tape to harddisk as seperate scene files?
By bolognese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 30th Jul 2009, 05:33 -
Sin City - movie over 50 seperate m2ts files - not all in sequence.
By Z.Sath in forum Blu-ray RippingReplies: 5Last Post: 11th Jun 2009, 16:45 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 03:57
