My God ..
I have tried a hundred different things now ...need som help.Trying to get a SVCD out of "Blade2" (that has 5 channel audio), and when i have burned a clip(10min) to test on my standalone dvd the audio is out of sync (1sec).The audio is in sync when i play it on a softwareplayer(power dvd).
I have ripped out the audio and done this to get a 2channel wave...
"Save the audio out using virtualdub, but use direct stream copy rather than full processing mode. rename the resulting file to file.ac3 rather than .wav. Convert this to stereo wav using Headac3he."
And i have used virtualdub to cut out a part and then used TMPGEnc to convert it in 2pass VBR.
The thing is ..that when i use the same settings on a avi(divx) that i got in 2channels everything works out nice and the audio is in sync too...So the problem must be in the divx(Blade2) that comes in a 5channel audio ,haven't done a SVCD from that kind of media before????
Anyone?? i'm big neeeeed..I have given this movie a week now ,cause the great quality it is made of.
If you had read the notes on your player you would have learned that SVCD audio sync was a common problem that can be avoided by using bbMPEG to re-multiplex your files and VCDeasy to create SVCD disks.
Thanks Man.
Didn't thought that my dvd player was the issue here, it played everything i created before....
I just created a clip using dvd2svcd and it's in sync. dvd2svcd uses bbmpeg so i belive your'e totally right.
Out of Sync only on Standalone player
By sambat in forum Video ConversionReplies: 2Last Post: 1st Sep 2011, 05:15 -
Burned blu ray on standalone player, I have audio but no video
By BAMFstang in forum Authoring (Blu-ray)Replies: 2Last Post: 19th May 2010, 13:28 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
no audio in divx files on standalone player
By kaston in forum Authoring (DVD)Replies: 14Last Post: 27th Oct 2009, 21:26 -
Standalone Divx player out of sync
By Tool Man in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2008, 19:31
