I am new to making vcd & I have have made a few using nero, however I have come across a problem, when i try some files it converts them larger than 1 disk.... how do i over come this problem...????
Some one please help a newbie......
Either split the file with TMPGenc, by using source range. or clip the input file by using source range, and make two files.
(Either way you have to reprocess everything)
Following these links;
http://www.vcdhelp.com/tmpgenc.htm about have way the text is the explanation about clipping the source range.
your welcomeYou can eat an apple but a pear you can
Sometimes I wish I were a girly just like my dear Papa ... (c) 1987 Monty Python -
Most MPG's are meant for 1 disk ( at a time ). Depending on how big the file is you MIGHT be able to squeeze it onto a CD-R by using overburning.
How big is the .mpg? -
the mpg is miles to big for overburn, i will try TMPGenc.
Watch this space for problems using TMPGenc..
Thanks for your help -
Alternatively, you can use DVTool3 to split the mpeg before writing it using Nero (or similar burning software).
DVTool3 is available for download @ http://www.musclesoft.de/combatman/sindex.html.
