I am trying to fit a movie onto one CD. I encoded it at a res of 352 x 240 because it looked less blocky than at 480 x 480, even though I have 'smooth block noise' turned on in TMPEGenc. But after the file is encoded, the size on my hard drive was like 744 MB, no problem right? NOT! When I went to burn it onto a cd with Nero and VCD Easy, it came up with a CD size of 850 MB! So what am I doing wrong? Is there a program for burning CVDs? Help!!![]()
Using the MPEG tools of TMPGen, specifically the Merge&Cut option, select MPEG-1 VCD then process your CVD file. Finally, record it using Nero as VCD. A 700 MB CD can accomodate up to 790 MB of a CVD file. E-mail me at believer@cheerful.com if you have more questions.
Not to slight the previous responce, but I have seen this before.
You probably miss clicked. What you are describing usually occurs when you by accident multiplex a SVCD as MPEG-2 VBR under TMPGenc. Go back and re-multiplex as SVCD.
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 21:51
