Has anyone here tried this? I d'loaded and applied the serial to get rid of the watermark and.....................WOW!!!!!!!
With the quality set at 10, high as it goes, the file size is only about 20mb a minute and VERY impressive quality!!! I'm going to do a couple of test caps and encodes and will post the results
actually.........
as far as merits of the codec,
1) low res like 320x240 it's great. Doesn't drop too many frames and the quality remains pretty constant with a smaller file than divx
2) trying to cap at like 480x480 forget it!! Unless my CPU is WAY slower than I think there are way too many frame drops for this to be of use
3) low res file swapping with your friends? Use it and do a fast repack with virtual dub into something a little more standard like divx and you will be amazed at the quality of a 1.2MB:1MIN file -
I apologize me for my required....there will be not another time !!!!
Pardon !!!
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Convert 4:3 PICVideo mjpeg to 16:9 DV w/o losing clarity
By brassplyer in forum EditingReplies: 12Last Post: 5th Jan 2011, 02:13 -
Convert H264 to AVI (PicVideo codec)
By dandaka in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 04:15 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 20:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41
