Results 1 to 13 of 13
  1. hey i just encoded a movie which is in anamorphic widescreen, but when i burn it as a xsvcd my dvd player freezes up and displayes a blocky picture. But if I just burn the mpeg2 file without formatting it as a svcd it plays fine, the only problem with this is i can't fast forward then. Can you not burn anamorphic on xsvcd? 16:9? Thanks
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Your movie is probably freezing because it's an xSVCD. If you exceed the limit of your player, this is a common side effect. Try reducing the bitrate. Are you using the standard SVCD resolution?
    Impossible to see the future is. The Dark Side clouds everything...
  3. no it's not that, I have the Apex Ad-1100W and it can read up to 8000Kbit/s for a xsvcd and i've tested this and my movie is on 1400 CBR.
  4. Member DJRumpy's Avatar
    Dallas, Texas
    Use Pulldown to change the DAR to 4:3 and see if your problem goes away.
  5. Member wulf109's Avatar
    Jul 2002
    You did not mention what program you used to burn the SVCD. I know for example early versions of Nero(4.0) would burn SVCD but scan would not work in a DVD player.
  6. I did set the DAR to 4:3 and the problem's the same. I'm using Nero 5.5. If I use Nero and just create a normal data cd and burn the movie that way the dvd player reads it fine. so it might be something with nero's svcd settings.
  7. Member DJRumpy's Avatar
    Dallas, Texas
    WienieMan, what version of 5.5 (i.e. 5.5.9.0 )? Also, what settings? Did you use the built in SVCD template?
  8. 5.5.9.0 I used The default template for svcd. just unchecked standard complaint.
  9. Member DJRumpy's Avatar
    Dallas, Texas
    When you left the 'Compliant' option checked, did you recieve an error, and if so, what was the specific error?
  10. It just says that the frame size is wrong (720x320) which is anamorphic widescreen.
  11. Member DJRumpy's Avatar
    Dallas, Texas
    xSVCD. Your not using any standard. Can't help you much, if at all.
    I did double check on the DAR flags. SVCD does not officially support 16:9, although your individual play might.
    My suggestion. Make a standard SVCD. They look fine on my 58" HDTV, I'm sure they'll look fine on yours.
  12. Nevermind I figured it out, I think i might of forgot the DAR the first render cuz i rendered it again and it works now. Thanks anyway man i really appreciate it.
  13. Member DJRumpy's Avatar
    Dallas, Texas
    To save yourself the trouble, you can switch the DAR using PULLDOWN.EXE, without re-encoding. Much faster.
