Does someone know how to make the subtitles look bigger?
how to increase the font size?
Is there a way to increase the font size in VirtualDub?
That is because I want to burn the subs into the film and then to encode it to SVCD using frameserve.
I'm using the Subtitler filter, in VirtualDub.
ya, of cuz there is...
CONFIGURE -> FONT -> adjust size.
*** i'm not quite sure of that, since i never use subtitles anyway... and i'm missing that filter for VDUB(but you need to look in CONFIGURE or SETTINGS or sumtin like that***Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
That depends on in what format the subs are - if it's SST or any other text format, then it should be possible (depending on the filter), but if it's in image format (directly ripped from DVD), then you have to convert to text format first.
/Mats -
yeah, check it first.... but I think most of subtitles are text format not a pix.... so, if it's a text format (.ssa and some other) then it should be work with alpha..... check out the alpha and change your front size or font... really easy.....
Question Re Subtitles in HDConvertToX
By morphjk in forum Blu-ray RippingReplies: 0Last Post: 10th Aug 2010, 07:19 -
Another question about subtitles
By du2vye in forum ffmpegX general discussionReplies: 1Last Post: 18th Oct 2009, 04:27 -
Subtitles question
By vanderbog in forum SubtitleReplies: 5Last Post: 8th Sep 2008, 00:11 -
Subtitles Question
By cowboysroy31 in forum SubtitleReplies: 4Last Post: 11th Jul 2007, 10:48 -
Question about Subtitles.
By vodmare in forum Authoring (DVD)Replies: 2Last Post: 13th May 2007, 07:38
