I have an AVI file with two audio streams. I'm trying to extract the second audio stream from it. I have tried to use Nandub, setting the audio stream 1 to "No Audio", then audio stream 2 to AVI Audio and saving the wav, but it says "No input audio stream to extract".
I tried selecting the video and second audio stream to make an intermediary .avi file that I can then extract the first audio stream from there. But, when it copies the streams, the first half of the progress bar it copies just the second stream, but the second half is spent just copying the video. When I try and open this intermediary for playing, there is no audio, just video. When I open it for editing in VirtualDub and try and save the wav file, it writes a 0 byte file and ends normally.
How can I get that second audio track out of there? If you know of a program that can do it, suggest a procedure too, I can't just stumble through the program till I find the way to do it.
Thanks, Nate.
I have the exact same problem (peter pan II dk-uk)
I also tried graphedit, it made a 1kb wav-file.
/jim
i have a video that has 2 audio streams..what does that mean?
By vincy in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 06:45 -
MP4 with 2 Audio Streams
By kohkae in forum Video ConversionReplies: 3Last Post: 26th Nov 2008, 12:47 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 20:00 -
multiple audio streams
By Tobberian in forum AudioReplies: 2Last Post: 14th Jul 2007, 13:54 -
Multiplex with two audio streams
By heretic754 in forum AudioReplies: 2Last Post: 2nd Jun 2007, 00:44
