I am having a problem. I have an .avi that plays perfectly on my PC. I have all the codecs (3.11, 4, 5, Nimo Pack). Here is the problem.
When I convert it to .mpg with TMPGEnc, the screen is a pink color. I read the most common problems portion of the website and it said to set the VFAPI to a higher priority in environmental settings. Well, I did that and it worked... sorta. The pink was gone, but the .mpg was only getting like 6FPS and it had big blotchy spots all over the screen. It was impossible to watch on my PC, yet alone on a VCD.
Well, I changed the VFAPI to a lower priority, and re converted. The resulting .mpg ran at the original FPS but it still did the pink thing. Im stuck, anyone help? Cheers.
I had the same prob, found this answer from forum user IncOg in another thread:
"Could be that you need the SMR codec installed.....u can find it here http://www.divx-digest.com/software/smrcodec.html"
This smr codec it works for me, no more pink spots!
Laptop Pink screen of doom! Please help!
By hellfire45 in forum ComputerReplies: 3Last Post: 25th Dec 2010, 12:24 -
Subtitle problem that fills screen with pink
By oldjoe911 in forum SubtitleReplies: 2Last Post: 27th Oct 2008, 13:54 -
When certain subs appear, the whole screen goes pink
By oldjoe911 in forum SubtitleReplies: 1Last Post: 9th Sep 2008, 17:14 -
YpbPr on Hdtv only shows pink screen.
By tiagirl in forum Newbie / General discussionsReplies: 4Last Post: 14th Apr 2008, 12:18 -
Problems with Subtitles Position on screen
By impulse_16 in forum SubtitleReplies: 11Last Post: 27th Oct 2007, 10:06
