A lot of these guides ( which there are so many and getting me more confused) use that maestro program. Being that I can't find it or it is no longer available, which program can I use instead?
It all depends on exactly waht capabilities/facilities you are looking for. The consumer level DVD authoring apps are a lot simpler to use than the pro ones like Maestro but are also much more limited in their capabilities. If you are ripping DVD's to DVD-r then you may well want to maintain the Ac3 audio. The only progs I know of that will import Ac3 are Spruce up and possible ULEAD DVD workshop. If you want motion menus, then ULEAD DVDWS again, or Dazzle DVD complete will do the job.
Hope this helps -
Yes, this helps. Thankyou.
I'm teaching myself with a lot of help from everyone here.
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 20:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
