Anyone know what this is??
I have an AVI which from the File Properties tab shows 'Unknown Tag (0055) under compression.
I know that 'Unknown Tag (2000)' is AC3 but have'nt had this onw before.
Any ideas on what it may be and how to convert s to a wav.
Thanks Mark
Don't know what Unknown Tag 0055 means, but i do know where to get a nice app that will tell you what codec you need to play that file (and what codec was used for your audio):
http://www.headbands.com/gspot/
Regards. -
Hi,
I'm not sure, but i think that this could be the signs of multiple audio streams. I saw this in one of my AVI's, and i know that it has 2 audio streams. -Morgan stream switcher-.
http://www.morgan-multimedia.com/mmswitch/
If you use BSPlayer, you can check it by rightclicking and see under "audio streams", it would show "Stream 1 - Stream 2...
Vineke
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
I have a virtual dub question.
By mmmipa in forum AudioReplies: 6Last Post: 12th Mar 2008, 03:34 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
