hey all.. any help would be very help full to me.
i have a few movies in avi format but i cant get them to convert to mpg format using tmpeg as it says tmeg doesnt not support or can not open these files! is there way of converting them using divx or another program.. ive tried just simply burning them with nero but i get the same problems with nero cant open or support this avi file((
thx guys![]()
Prob'ly missing codecs.
Try installing Nimos codec pack (link under TOOLS).
Clean your box from spy/adware after install.
/Mats -
Open TMPGEnc, go to Option->Environmental Setting...->VFAPI plug-in, select DirectShow Multimedia File Reader, right click and choose Higher priority as many times as it needs to get value 4.
Now you should be able to load any avi file unless it is corrupted or an XviD AVI.
Regards. -
The DirectShow Multimedia File Reader filter can be tricky.
Sometimes the opposite is true. If a high priority doesn't work then try unchecking the directshow filter. So another avi reader will be used.
It depends on which codec was used to compress the avi ...vfw versus directshow.There's not much to do but then I can't do much anyway.
Open ffdshow config screen without opening a movie
By F u r u y á in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2013, 05:15 -
Do you try to see a movie during the opening weekend?
By yoda313 in forum PollsReplies: 23Last Post: 12th Aug 2008, 12:32 -
opening .z files on a mac?
By jwnulife in forum MacReplies: 1Last Post: 20th Mar 2008, 09:53 -
Movie in 2 avi files but with different resolutions
By LaLuna in forum Video ConversionReplies: 4Last Post: 24th Nov 2007, 22:00 -
Opening Movie
By Gunna in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2007, 18:08
