When I file serving avi from virtualdub to
Cinema Craft Encoder (3pass vbr)
encoder says later that scource is not same
that last time...
any help...
Thanks for attention
Venkku
I think that this happens when DCT is set to automatic and/or when encoding audio at the same time. Try to set DCT to fixed value (8, 9 or 10) and encode audio separately from the video stream.
I assumed you meant cce complained about the checksum error. If that's the case, the solution to apply the crc removal patch
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
