  1. Like the subject says, how do i remove subtitles from an mpg file? Thanks.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    To be honset, there's no other way than cropping the MPEG. There's simply no info in the MPEG regarding what's supposed to be behind the subs.
    /Mats
    Jun 2001
    England
    Some DeLogo filters will give a best guess as to what is behind the subtitles by analysing the surrounding pixels. It is not a particularly effective technique and 99% of the time you just end up with a blurred mess once the subtitles have been removed.
    If the subtitles are alpha blended (i.e. partially see through) then it is possible to remove them completely.
