Sorry if this is a daft question.
Can any capture cards be configured to get their data from a file rather than S-VIDEO?
Reason for asking is that I have a digital Camcorder and am concerned about loss of quality by feeding through S-Video.
Thanks.
DJ
Digital Camcorder !! lucky you.
Get a 'firewire card' if your camcorder supports it.
Miminal data loss. -
I have a FireWire card. The question (which I should have been clearer about) relates to encoding to MPEG1/2 after I have transfered to disk.
In other words, I would like to use the encoding hardware of the cards, but get one to get the input from a file, rather than SVIDEO. -
Ya lost me here ?!?!
If you have a DV camera and FIREWIRE card then that's it.
http://www.vcdhelp.com/capture.htm
Capture through the firewire card to the harddrive in DV format . ....... edit away
Then export to MPEG1/2 using anyone of many programs
http://www.vcdhelp.com/convert.htm
I think DJANDA is wondering if any of the hardware based MPEG video cards can take the data from a file and run it through their hardware encoder and produce an MPEG file faster than what is typical of the software encoders.
Hi guys,
That is what I'm thinking about. I want to use an older PC as an DVD-Player and for caputering DV-streams. But it has only a AMD K6-2+ 500 Mhz CPU. Is that power enough to software-encode or do I have to use an additional encoding-card? Does anybody know of a combination of a (cheap) MPEG2-encoding-decoding card? As far as I know, most of the MPEg-cards coud only be used in one direction (endcoding or decoding, but not both)
Hi8 capture- Suggestions for Harddrives and Capture Cards?
By CMP1223 in forum Capturing and VCRReplies: 7Last Post: 11th Jun 2011, 00:05 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Help with Video/Capture Cards.
By drsimp12 in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2007, 07:05 -
Interferance on capture cards
By Signal in forum Capturing and VCRReplies: 35Last Post: 13th Sep 2007, 22:26
