I downloaded and installed nimo tonight (unistalling Divx5 free/basic first). If i now try to open a file (even one that worked before) MP 7.01 crashes. If I click on the file in windows explorer to check its properties, explorer.exe crashes. I can open the files in virtual dub fine though.
Any ideas?
Uninstall the pack and be selective when you reinstall. Some codecs in the pack can cause conflicts
There's not much to do but then I can't do much anyway. -
Sorry, Im back
I have a lot of "green" with one AVI using mediaplayer. looks fine in virtualdub though.
Is your motherboard using VIA chipset? If so, you can try download the PCI Latency Patch for VIA chipset at http://www.networking.tzo.com/net/software/
Just a suggestion. Not sure this can help. -
Thanks, the VIA update did not correct the problem. Maybe it will help the occassional freezes I have when watching videos.
Going to create new thread.
MKVMerge output file and windows explorer crash
By majid_aryaee in forum SubtitleReplies: 13Last Post: 19th Oct 2012, 03:26 -
C# program always crash when creating Windows Media Encoder object
By George2 in forum Newbie / General discussionsReplies: 7Last Post: 9th May 2009, 05:46 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 22:49 -
AVI did with Huffyuv codec cause crash in explorer.exe
By PalmTX in forum Capturing and VCRReplies: 5Last Post: 15th Feb 2008, 17:09 -
Pinncle Studio 9.4.3 worked just fine, now CRASH CRASH CRASH
By maxtrack in forum Newbie / General discussionsReplies: 18Last Post: 11th Sep 2007, 00:38
