I want to make a rip from a DVD with the original DVD menu. But now I got some problems to sync the chapters with the new movie stream. I ripped a DVD to a lower bitrate in DVD compatible format and Authored it with one audio stream and 5 subtitles with DVDMeastro. So I got now new .vob files which contain the same chapters as the DVD. Now I want to use the original .IFO files to keep the menu. This works fine but when I want do select a certain chapter my DVD player jumps to the wrong place in the film. I guess that I need to update the sectors in the original IFO, so that the player could find the right place in the vob file e.g. if I select chapter 9. Do anyone know a method to update these sector infos? I couldn't to this manualy because there are more then 1000 lines. It would take too much time to to this.
thanks,
Nathon
Results 1 to 1 of 1
+1 audio steam to the DVD with original menu.
By kurochocho in forum Authoring (DVD)Replies: 0Last Post: 12th Jul 2011, 10:48 -
3D Bluray reauthoring with multiAVCHD is generating almost 2x original size
By afss2010 in forum Blu-ray RippingReplies: 14Last Post: 4th Apr 2011, 11:54 -
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
Original DVD Menu
By cavusozkan in forum Authoring (DVD)Replies: 8Last Post: 17th Feb 2010, 21:54 -
Keep original DVD menu, add new movie file
By Booklet in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2009, 16:21
