I have a Sony DCR-TRV 103 digital 8 camcorder and a generic firewire card with Ti chip set. I was able to capture my digital 8 tapes and create vcds using Adobe Premiere 6, TMPGEnc and Nero 5.5.
Yesturday, I tried following the capturing prcedure posted in this site and in www.dvideohome.com. I hooked up my VCR to the Sony camcorder and tried to capture the movie real time ( no Hi-8 tape inserted in my camcorder). The result was I got no frame captured.
My question is - Do I need to transfer the vhs onto a digital 8 tape first before I can capture the move from the digital 8 to AVI? If not, how I can do a real time capture without the transfer?
Your insight/help/trick is highly appreciated. Thanks.![]()
Results 1 to 10 of 10
Hi
I believe that your video camera do not have DV in.
Check if you can record from video straight to dig8 tape.
Good luck. -
The following are how I am connecting the vcr, the digital 8 camcorder and my pc.
I was using a RCA cable to connect the vcr to my digital 8 camcorder and a firewire cable to connect the digital 8 camcorder to my fireware card on my pc. The iLink port on the camcorder is In/Out capable acording to the manual and I was able to capture movie on my digital 8 tape through the port to my pc using Adobe Premiere 6.
Thanks -
I was able to use my sony to pass through the signal w/o a tape in using the following chain...
VCR RCA outs > TRV330 RCA Ins > Firewire Out > Firewire In > Premier 6.0
I had no problems, I used it to record a tv performance.
hope it helps a bit
Cal
ChitownTaper@attbi.com -
Mr. ChitownTaper
Can you think of any cruial configurations that I may missed either on the camcorder or the Adobe software? Thanks. -
Okay, I just did it again as a test for you and I don't have any special settings.
Are you switched to VCR or Cam mode? It needs to be on VCR.
Other than that it's pretty much the way you'd set up a regular vcr and then just use the firewire out.
cal -
When I did it, I was using VTR/VCR mode on my Sony camcorder.
Thanks for you reply. -
You have to select DV out from the camcorder's menu for the passthrough feature to work.
If you live in Europe, the process is a bit more complicated since you must activate the recording capability of the camcorder. -
From what I can see on the web, the 103 does have analog in so you should be able to capture analog to D8 tape. I couldn't confirm that the model has analog passthrough which allows conversion without first going to tape.
If you do have analog passthrough, you should be able to find a menu choice that says AV / DV Out with a yes/no selection.
There are several Sony models without passthrough and also several European models (I think with an "E" at the end like TRV-120E) which have passthrough disabled. -
My Sony trv310 doesn't have pass-through. Yours may not have this capability either. All Sony's are not created equal! I can input analog from a vcr or other analog source, and I can output digital video through my firewire port, but not at the same time. Any time a signal is sensed on the analog input ports, the firewire output port is disabled on my camcorder. A search on the terms, Sony and Pass-through should get you enough info to determine if your camera has this capability. There should be some reference to this feature in your manual too. Hope this helps.
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 10:54 -
converting Hi8/S-VHS or even VHS to digital
By lawncowboy273 in forum Capturing and VCRReplies: 2Last Post: 23rd Dec 2010, 19:30 -
sony camcorder/kodak digital picture frame
By 0mike0 in forum Video ConversionReplies: 2Last Post: 25th Apr 2009, 01:22 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47 -
Re: Sony Digital Camcorder HDR TG3E Various
By billbirchall in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2008, 13:06
