Is it possible to insert text into mpegs (SVCD)?
I have some home VHS tapes and old anime that I want to make into SVCD's and it would be nice to add text and titles to them.
I have found that after much trial and error over the past few months that PowerVCR captures the best for me. Even though AVI is the preferred format for video editing, I just cant seem to work out all the bugs in my set-up to allow for good .AVI captures (frame drops, synch issues, freezing). Capturing direct to MPEG2 works perfect when i use PowerVCR, so that's what i prefer to use. It boils down to either having a crappy quality capture card or my 761/VIA chipset isnt ideal for doing this type of stuff.
(History: As far as AVI captures go- Ive tried almost all of the programs in the "tools" area, plus a handful of ones not in the list, and basically they all sucked. I tried to the generic drivers instead of the ATI 7.1's and that didnt help. Everything is tweaked and my computer runs perfectly)
Thanks for any advice,
My specs are in my signature.
ATI TV WONDER PCI, AMD 1600, GA7DXR-AMD761, 512DDR, HD's: 40MB+40BM+30MB, PNY G3, XP Pro.
Can't believe you can capture to MEPG-2 but can't capture to AVI with good quality.
Yes, you can add tiltles and text to your MPEG-2, but it also depends on how you want to do it. The simplest is to add some introductory titles and texts in front of your MPEG-2. If you want to superimpose titles and texts on to your MPEG-2, it becomes much more complicated. I am afraid that you can't do it without re-encoding. That's why you should capture to AVI in the first place, it keeps best quality and is much easier to edit. -
also you can use adobe premiere
Today is the last day of the rest of your life -
Thanks for your replies.
I cant capture bigger than 240 x 320 (or whatever it is, its close to that).
I have installed VideoWave 5 and have successfully made a 3 minute test clip (AVI) and was able to add text easily. Tonight I'll experiment with a full movie.
As far as VirtualDub, VirtualVCR, and all the other tools, I have had too many glitches with all of them especially regarding sound cutting out.
Even Premiere 6 has given me some headaches- mainly becasue of its complexity.
Videowave is really easy to use and works so far.ATI TV WONDER PCI, AMD 1600, GA7DXR-AMD761, 512DDR, HD's: 40MB+40BM+30MB, PNY G3, XP Pro.
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
Creating simple text/image to prompt 'Insert Disc 2'
By rbatty11 in forum EditingReplies: 11Last Post: 15th Feb 2009, 12:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
What is the best way to insert text into VOB files?
By SUPERIOR in forum EditingReplies: 2Last Post: 15th May 2008, 03:34 -
How to convert titles to text
By TKB in forum SubtitleReplies: 0Last Post: 2nd Oct 2007, 02:18
