ok i wanna transter my camcorder videos into divx how would i do this thankx in advance and what programs will i need.
Results 1 to 9 of 9
Its all about HHH the GAME, Lakers, 49ers, Dodgers,UCLA Bruins.
NANDub should do the trick. You should be able to find it in the Tools section, or at www.doom9.org. You'll also need the DIVX codecs installed ( www.divx.com ).
For the rest, just refer to the guides (see How To - Newbie to the left )Impossible to see the future is. The Dark Side clouds everything... -
thanks but NanNub wont dl i keep getting a error on it when i try to dl it
Its all about HHH the GAME, Lakers, 49ers, Dodgers,UCLA Bruins. -
It's mirrored all over the internet. A quick search on Google should net you a list of sites that host the software for it. As another option, use the tools at the DivX site.
ok got it but my video wont decode the video is avi does it have to be vbr or cbr ? thankx in advance
Can you be more specific? What do you mean your video won't decode? Are you having problems loading it into NANDub? Are there any errors reported? etc...
sorry about that.
ok i capture with scenalyzer live through my firewire card then i open nandub and i get some error saying something about some microsoft video driver and it wont open my avi file on nandub.
also under video should it show Divx? and should it say No AVI ?
do i have to put the divx codects on the nandub folder?
thankx in advance i will try to take some screens of it later todayIts all about HHH the GAME, Lakers, 49ers, Dodgers,UCLA Bruins. -
It sounds like your missing a Codec. Look at your scenalyzer documentation to see what's required to convert your file. Unfortunately, I'm not familiar with scenalyzer at all.
As for the DIVX codecs, just install the DIVX package. It will place the codecs in the necessary locations for you. You do not have to manually place them anywhere.
You should try one of the Codec packages, like NEMO (see the tools sections on the left, and scroll towards the bottom). They install most of the codecs you'll need for you.Impossible to see the future is. The Dark Side clouds everything... -
Try using MainConcept DigitalVideo (DV) Codec for Win32 v2.04
It is opening AVI files from DV using Virtual Dub.
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 10:34 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 03:09 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 17:13
