is there any program that do this?
i just wanna see if the avi file im downloading is real
Use the search function. The answer has been posted before.
There's not much to do but then I can't do much anyway. -
you cannot do it, because the format of the avi file need to have a begining and an ending. but you can copy the file you are downloading to another directory and use DivXFix (can find it on tools). sometimes i used in this way an it works for me.
Today is the last day of the rest of your life -
If you want to just view the video (no audio) ,you can load in into TMPGE > File > Preview
"Today is only yesterdays tomorrow" -
Ok it may be hard to search for my previous post so here's some help.
Copy the dat file so you can let the download continue. You can copy it while it's downloading.
Open virtualdub and in the file open menu when the dir opens click on the box that says "Popup extended open option" and then choose the copied .dat file in the directory window. A new box will open.
If its an mpeg choose accept partial mpeg stream. If its an avi it will reconstruct the index automatically but don't select the "redrive key frames" option because that's slower. When you press preview under the file menu don't play with the video since you did not re-drive the key frames the search will be slow. Let it play when you are satisfied close vdub.
That's it.
If its a busted download near the end and you want to keep it then do the redrive key frames and resave the avi.
Enjoy!!!!There's not much to do but then I can't do much anyway. -
Hey ..Baldrick...
Just tried that AVIPREVIEW....awesome!!!!
Thanks...been looking for something like that for a while!"Today is only yesterdays tomorrow"
Subtitle Workshop not showing mkv files during preview
By tuna1013 in forum SubtitleReplies: 27Last Post: 26th Jun 2014, 14:57 -
multiAVCHD will not show files in transcode preview that it did previously
By Onceler2 in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Oct 2011, 22:20 -
Batch Processing 2.34:1 AVCHD Files for preview
By goanna300 in forum Video ConversionReplies: 17Last Post: 28th Jun 2011, 02:45 -
Sony Vegas 8, files size preview?
By cshortt in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 11:25 -
Using Divx Preview for mkv support but no audio on some files...
By AndyD in forum AudioReplies: 9Last Post: 22nd Nov 2009, 16:25
