Can somebody show me how to convert a .avi file to mpeg-2 SVCD. ??? I can do it using TMPGenc. When i import the .avi into TMP. It said that..."unsupported format" but I did alot of avi to mpeg convert before and there's no problem.. Maybe it's the way how Formula 51.avi was saved ???
Results 1 to 9 of 9
-- The Newbie GuidesIf you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Sounds like your problem.Hello. -
Hi..thanks for the reply...i got divx and started to encode..but after 6% encoding my .mpg files is 286meg already...how can that be....I used the default settings in TTMPG. The original avi file can fit on one cd. Is there a way for me to encode that same avi about 700 meg into the same size mpeg ?
VCD = 10MB/minute
SVCD = ~15-20MB/Minute
You do the math.
You can shrink down mpeg, but it's no longer a standard and may not play back properly on standalone DVD players. -
OK...I need help again...So I did let TMPG. encode my Formula51.avi to .mpg. but i got an error at 20% saying "Write error occurred at address 00485E76 of module "TMPGEnc.exe" with 01A7D000" ?? any idea ??? Oh yeah...at that time my .mpg what was stopped at 20% is 960MB already.....
Note: all TMPGEnc setting are defualt and using SVCDFilm template. -
Go back to the AVI. In Virtual Dub, select Video-->Scan video stream for errors.
Hello. -
Ok i did ran it through VirtualDub...and check for errors..but no errors were found...soo now what ??? please help
Help with an IF/THEN formula in EXCEL
By Rudyard in forum ComputerReplies: 4Last Post: 13th Sep 2011, 02:53 -
What is the mathematical formula to figure out the right resolution when resizing?
By Newtype in forum Video ConversionReplies: 10Last Post: 8th Feb 2010, 18:11 -
Formula for encoding flvs
By stembridge in forum ffmpegX general discussionReplies: 5Last Post: 12th Sep 2008, 19:23 -
Math: Equation / Formula questions
By vhelp in forum ProgrammingReplies: 7Last Post: 27th Jul 2008, 17:06 -
Formula to calculate closest integer divisible by 16 ...
By ptfigg in forum ProgrammingReplies: 10Last Post: 11th Jul 2008, 11:04
