I have been spending days trying to copy a 16X9 DVD to a DVD+R.
I use: Smartripper, DVD2AVI, TMPGEnc, and Maestro. All the settings are correct from what I have read from others. When I playback the final .vob file, it looks fine and is widescreen. When I use Nero 5.5.9.0 to burn the disk, it is stretched to fill the screen.
I have used all the "how to" guides here. I am starting to blame Nero since the .vob files look fine.
PLEASE HELP!
r
ADDED NOTE: I found the post about changing the setting on DVD Maestro to "16X9 widescreen", but that made no difference.
Have you done this with ifoedit http://www.dvd2dvdr.com/Normal%20tv.htm works for me EVERY TIME.
jolly: when you burn what format are you using? DVDVideo or DVD UDF/ISO? I'm wondering cause this is like the 4th time lately I've seen this been asked.
Anyway if you read the other post on the main screen like yours I tell you how you can fix it by editing the ifo.
If you are having problems and using DVDVideo the I suggest trying UDF/ISO. -
I found out what the problem was. It was the 16X9 setting in Maestro. I still had it set for 4:3. Someone else had told me that this setting was not necessary, but obviously it is.
Thanks!
-r
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15
