Hello
I have a problem when i was trying to burn a movie downloaded from the net size 760Mb. Nero starded out fine and started to encode the file but after 1.18 hour it stopped and said error encoding. Anyone can help me?
Regards
Joakim
Yes. Don't use Nero to encode your videos.
It's a fine piece of CD writing software, but not a competent MPEG encoder.
Use TMPGEnc or CCE or something to encode your movie to the MPEG format of your choice, then preferrably use VCDEasy to author&burn, or VCDImager to create the CD image and then Nero to burn that image.
(There's most likely something wrong in your downloaded file - take a look under EDIT/How to repair downloaded video clips or fix audio sync problems for info on how to deal with this)
/Mats
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 19:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 13:33 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 18:50 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 16:08
Hello
