In the past three day i tried to create v-cd for my thomson dth 500 s with Nero (last version) and other dedicated software...
Unfortunately, I always receive 'no disc' error.
The question is: may this error depend by the 'Menu' at the beginning of the v-cd?
Tks in advance.
I've read posts from people reporting that their stand-alone wouldn't play VCD's with menu (when made with Nero) (this is my own experience too) but that it'd play the VCD when no menu was created by Nero (haven't tested - dumped Nero as a lost cause when it comes to VCD).
If you still want menus and stuff, try VCDEasy for your authoring/burning needs!
/Mats -
Try putting in an audio CD on the same media type.
Does it play on your player?
Chances are that your player simply doesn't play CD-R/W media... If this is the case, you will need to experiment with different brands of CD-R to find one that works. CD-RW often works better in these cases.
Regards.Michael Tam
w: Morsels of Evidence -
Let me set everyone straight! The average bit rate for a DVD is 5mbps or in otherwords 5000kbps. If you don't trust me here is a links to were you can find the info yourself http://electronics.cnet.com/techtrends/0-6014-8-9709541-1.html i hope that i helped you all. Anyway most VCD are about 1115kbps so you were right all along!!!
Well said K.I.S.S. !!
We don't know why your saying it, but well said!Impossible to see the future is. The Dark Side clouds everything... -
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Continuous play of root menu audio throughout all menu's
By breakbred101 in forum Authoring (DVD)Replies: 3Last Post: 28th Apr 2009, 18:37 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
