What is the best way to play .m2p mpeg files. I know that power DVD won't play them. Is there another software DVD player that will play them?
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Etymonix SoftReel MPEG-2 Video Decoder Filter 1.10
Etymonix SoftReel is a software-only MPEG-2 video decoder filter for Microsoft DirectShow. It enables playback of native MPEG-2 files (*.mpg, *.m2p, *.m2v, *.mp2) in any application that supports DirectShow, such as Windows Media Player. Its key features are: Decodes MPEG-2 4:2:0 and 4:2:2 video streams at all profiles/levels (excluding scalability extensions), including Super Video CD (SVCD), unencrypted DVDs (with an MPEG-2 audio stream), ATI .mp2, 'EM2V' AVI and 'PIM2' AVI files. Enables MPEG-2 audio playback from MPEG-2 files. Exceptional video quality achieved using highly precise computations. Fully compliant with Microsoft DirectShow (also known as ActiveMovie). Full IPB frame support (any GOP sequence). Frame-accurate seeking within AVI files. A wide range of resolutions (up to 768x576) and frame rates, including NTSC (720x480, 29.97fps), PAL (720x576, 25fps) and SVCD (480x480 or 480x576). Correct scaling of video contained in SVCD and ATI .mp2 files (accurate aspect ratio). Can easily be integrated into DirectShow applications (for developers). Ideal for kiosks, PowerPoint presentations and watching video clips. Optimized for MMX. Supports both Intel and AMD CPUs. Works with a wide range of players (including RealOne Player and all versions of Windows Media Player). Supports all screen resolutions and all pixel depths. Runs under Windows 95/98/Me/NT4/2000/XP. User-friendly setup program fully automates install/uninstall procedure.
I think that will do the trick
i found it there: http://www.softlandmark.com/VideoEncoder1.htmWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Thanks, I'll give it a try.
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Convert to M2P
By BuzzStPoint in forum Video ConversionReplies: 4Last Post: 25th Dec 2009, 13:24 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 20:23 -
Some video files and movie files won't play
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 21st Feb 2008, 10:08 -
Can't play WMV files
By cheerful in forum Software PlayingReplies: 3Last Post: 4th Sep 2007, 07:06
