Hi to everyone!
I'm looking for a codefree dvd player with a NTSC/PAL system conversion output (could play PAL discs on a American "NTSC" TV) and so far I found Sampo and Malata.
Which one is better? Is there any other company that include this feature?
Thanks a lot! Nick
P.S. Good links will be useful too!
Hi,
Check ou the Amoisonic 8506(F). Its region AND MacroVision free ! Has 2 Scart Ports, Karaoke functions and NTSC output when playing PAL DVD's.
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
I 'll go for the Malata n-996. I have one I've played region one discs (with RCE) and the quality is as good as the Pal discs. So I guess playing a Pal disc onto a NTSC tv will be the same. It has a built in converter.
Take a look at this site http://www.avdeals.ca/malata_dvd.htm -
Sampo, Apex, Shinco and Skyworth, just to name a few, are or can be made code free and Macrovision free, and can do NTSC <-> PAL.
However Malata is the best so far, since it has X and Y adjustments, your converted picture can be adjusted so it won't appear squished like the other players.
Malata N 996: Progressive scan with Karaoke and AC-3 decoder hence more expensive, but no Macrovision hack.
Help with Malata DVD player
By Vanderzam in forum DVD & Blu-ray PlayersReplies: 12Last Post: 26th Jan 2010, 21:26 -
Help Malata DVP-810 free region
By DiegoC in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Oct 2009, 10:24 -
malata dvp-520
By jfethiere in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jul 2009, 19:57
