  1. Hi,
    I have managed to rip the main DVD film and made it into a VCD.
    I am now trying to get the special features ie the making of . . . etc but the audio tracks are not in the same track.
    I only have 8 tracks on the DVD, but how can I find out which is which. I know track 1 is the english movie. There are 3 other languages supported then, and 8 tracks listed in dvd2avi.
    Are there any programs/untilities that will let you listen or see what tracks go to what parts of the dvd etc?
  2. Hi,
    I ran into the same problem. I don't know if any program out there can tell exactly which track the audio is on. What I did was trial & error method, just select a track, start Save Project, then look in the Statistics Window. If nothing shown under Audio Format, then stop the encoding. Do that untill you see something under Audio Format, for example DD 2/0 192.
  3. Hi,
    Cheers for that. I ended up doing the trail and error method. Was a bit longwinded, but it does work.
    Cheers again
    Dave
