  1. hi
    im sure there is an answer to this somewhere on the forums but i cant seem to find it so sorry for the repetition.
    Q) i have a divx file downloaded from the internet and when i try to convert it to a mpeg file using tmpg it states that the file is going to be bigger than 3000mb. i must be doing something wrong as i thought i could get movies on about 2xcds. the file is divx3 encoded and the audio is mp3 lame encoded.??
    any help would be appreciated.
    tia
    rob
    Apr 2002
    The State of Frustration
    What template are you using to convert it to (S)VCD or DVD?
    Hello.
  3. the standard one that come with tmpg for pal and ntsc.
  4. Does the divx have variable bit rate audio. Open the file in virtualdub and see if you get a warning about VBR audio if so follow this guide.
    http://www.vcdhelp.com/virtualdubaudio.htm
    Assuming you hav'nt upped the bitrate, or you don't have a 300 minute video, this could account for the problem you are getting.
