Since I have a Pioneer CD CDV LD Player CLD-97, could it play vcds? Would it be VCD1.0, or VCD1.1, or VCD2.0. Or would it have to be CDV format??
-TIA
Wasn't exactly a DVD hardware question, but my Pioneer CD CDV LD Player CLD-97 is hardware.
Some LD players can play VCDs.
Some cannot.
CDV is akin to LD video on a CD media and is not related to VCD.
Regards.Michael Tam
w: Morsels of Evidence -
More specifically, Laserdiscs are not entirely a digital format -- the video information is stored, if memory serves (and it's been a while since I actually read up on this, so I won't swear to this in court
) using a combination of AM and FM modulation encoded as differences in pit size and depth. Therefore, you cannot burn "CD-Video" format in a standard CD-R(W) or DVD-R(W) burner since, as vitualis points out, what they called "CD-Video" back then was really just a five-inch Laserdisc that typically held somewhere around six minutes of video (usually an MTV music video) and a couple of CD-Audio tracks.
These types of discs are totally unrelated to the White Book "VideoCD" standard, which is an all-digital format based on standard CD recording and data formats.
Most LD players, unfortunately, pre-date the White Book standard and cannot play VideoCD's... and the only way I know of to find out is to burn a VideoCD and try it.
How to convert CDV Files
By roxics in forum Video ConversionReplies: 8Last Post: 29th Sep 2010, 11:47 -
Television compatibility
By CACTUS1944 in forum DVB / IPTVReplies: 9Last Post: 23rd Nov 2009, 13:34 -
Windows 7 Compatibility
By MOVIEGEEK in forum ComputerReplies: 15Last Post: 3rd Nov 2009, 17:06 -
RAM compatibility.
By A Traveller in forum ComputerReplies: 35Last Post: 20th Oct 2009, 14:09 -
CDV's from the 80's/90's
By ChaunceyK in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2009, 08:16
