Results 1 to 9 of 9
  1. I have made 5 .vob's using DVD Decrypter.
    Do I have to convert to AVI before encoding with TMPGE?
    I did a quick test and TMPGE seems to accept the .vob's ok?
    My last question is.......is there an easy way to append the 5 vob's during the encode process (can't seem to figure out a way in MPEG Tools or by using batch encode )??
    "Today is only yesterdays tomorrow"
  2. use dvd2avi to frameserve the vobs into tmpgenc
  3. I have used dvd2avi to frameserve the vob files, the d2v and wave files have been successfully created. But, i have a problem when try to load the d2v file into tmpgenc. Only the wave file can be loaded.
    What is the problem?
    The versions i used are
    dvd2avi - (1.76+ LOLI.J)
    tmpgenc - (2.58.44.152)
  4. kim - see reply to your other post with the same question:
    http://www.vcdhelp.com/forum/viewtopic.php?t=120801
    (some mods on some forums get quite annoyed about posting the same question in lots of different places by-the-way)
  5. Sorry, I never meant to do this.
    Thank for the answer. It really help, the problem have been solved.
  6. Member wulf109's Avatar
    Jul 2002
    Wee Hagis
    A properly installed Tmpeg will open vob files,but only one. You could rip the movie as one large file,all rippers have this option. DV Tool could join all 5 vob's into one for Tmpeg. Some vob's conatain PTS pointers which trick Tmpeg into stop encodeing. I never frameserve my DVD rips,I always encode directly in Tmpeg.
  7. Originally Posted by wulf109
    Wee Hagis
    thanks for response...
    the problem is,if my win98 Fat32 hd can only take 4gig....then assuming the average DVD is over 4 gig,I will be unable to do it "in a oner".
    So....you are saying that if I was able to rip as 1 VOB,TMPGE would easily be able to encode directly?
    If this is the case,does it take any longer than the DIVX to VCD encode process with TMPGE?
  8. Member wulf109's Avatar
    Jul 2002
    Yes,the 4GB limit will prevent you from doing most movies as one large file. I rarely encode from avi,but I don't think encodeing from the vob will take any longer.
  9. Originally Posted by wulf109
    Why do you do this? I use dvd2avi to frameserve, and have never had probs. Does doing it this way give you a better quality?
