hey whats up so far i have been making a dvd with maestro. i do not have a help file with mine but after playing with authoring programs it seems easy enough to figure out, till now. Currently i have a film with 2 audio tracks, a 2.0 and a 5.1 ac3 (for the record). I have my main menu, and then i made an audio selection menu where i have 2 menu buttons for each audio track.
How can i link these buttons to the 2 audio tracks i have for my video clip? I tried a few things but no dice. I could use some info asap, any help would greatly be aprreciated. thanks again
nevermind i was able to solve the problem, also that wondwerful help file from the doom site was very beneficial as well
Hello.
I ran into the same question today. What did you do to get this working? Thank you.
Jason -
import you clip, then select whatever menu it is you want toe audio tracks to be selectable on. Once you do this make sure you enlarge the pic so this wya the rest of the menu information shows on the bottom (just hit the enlarge window icon on the top right), make your buttons then for each choice for audio you will see a "buttons" tab on the bottom, under this tab on the right is "stream pre selection" you will see "set audio to" and if you have 2 audio tracks, set the first choice to 1 and the second choice to 2, etc-- thats all you have to do. if you do this the button will still say that their is no target, but its ok--
Guess it would help if I converted my dts file to something that Maestro can recognize. Know of anything by chance?
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Removing audio tracks from DVD
By txl in forum Authoring (DVD)Replies: 2Last Post: 26th Nov 2009, 11:06 -
DVD audio tracks
By andreltr in forum Authoring (DVD)Replies: 3Last Post: 13th Aug 2009, 00:22 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 16:45
