I have used DVDRIPPER to rip a DVD, I then DVD2AVI to create the .WAV and the .d2v files. I then used TMPGEnc to convert the video to an .MPG like the tutorial shows. I used sefy's template and the .MPG ended up 710 megs. Ok, first of all my Media Player will not play the file (do i need a different codec or something?) and second of all the movie was only about 85 minutes long to begin with, so how can I burn 710 megs to a 650 meg CD? Does the burning software compress it or something?
ICQ #: 127670178
Results 1 to 11 of 11
A) What version of media player, get the most recent, should always play an mpeg fine file w/o another needed codec
B) when storing data on CD, you ignore the MB # and think in turns of mins..650 = 74mins, which in turn if you burn a standard VCD, 1150kb/s video & 224 kb/s audio, you can estimate you movie size to a ratio of 1 min = 1 MB, therefore on a 650/74 mins CD, you can 740 MB worth of video...video info is brun in mode 1 format, data info is burned in mode 2 format..thats why there is a difference
C) Now the catch is, if you stray from a standard VCD, you can throw that ratio out the window....and then you have to use a bitrate calculator http://www.vcdhelp.com/calc -
well, my media player version is 7.01.00.3055.
The file that was created is an MPEG but when I try to play it, it says "An invalid media type was not specified". So now I am lost. -
hmmm that is intesresting..only thing I could say is download realplayer..and see if you get the same error...if so, then Im lost myself....if not, then maybe an reinstall of WM7 is due??
Since you've mentioned you used my SxVCD, then it would explain the trouble you are having, as Media Player does not support the playback of MPEG2 files, not unless you have a MPEG2 Decoder installed, something like: LSX Suite, PowerDVD, WinDVD
As for the burning, if you read the included text file with my Templates you will see that you need to use Nero to burn the file as a Non-Standard Super-Video-CD, but please do check your DVD Player and see if it's on the list of supported players, and if not, I suggest you first try using a CDRW.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I had the same problem with media player, I downloaded Divx 4.0 from the Tools section of this site, and now mine play ok.
You might want to try this if you haven't already.
Macca -
Divx is an entirely different coding format...it won't help him. Sefy's comment about needing an MPEG2 decoder is almost certainly the correct solution.
the movies play fine in Power DVD, so I guess I need a codec, anyone have a suggestion as to which one to get?
If you have PowerDVD in your computer, There should not be any problems to play movie with Media player. Try to uninstall and re-install Power DVD, that might help.
try downloading the mpeg-2 decoder from http://www.elcard.com
it may help you out. -
It sometimes happesn that PowerDVD codecs don't get intergrated with Media Player, and as suggested, uninstalling and reinstalling could help, and as for a MPEG2 Codec, you can also install LSX Suite v2.0 it will install the codecs into Media Player and you will be able to play any variation of MPEG.
Best Regards,
Sefy Levy,
New guy saying hi
By Hanssen069 in forum Off topicReplies: 13Last Post: 8th Jul 2011, 17:20 -
never mess with an old guy on the bus
By deadrats in forum Off topicReplies: 4Last Post: 5th Mar 2010, 22:54 -
new guy
By harrisonhouse in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2008, 07:03 -
How did this guy get on tv?
By redstripes in forum Off topicReplies: 2Last Post: 25th Jan 2008, 16:31 -
Who is this guy that is trying so hard???
By fLYtRap in forum ComputerReplies: 12Last Post: 1st Jul 2007, 17:06
