I recently bought a new leadtek winfast a250 le td myvivo 128mb videocard.
Now I have been trying to capture something for a couple of days now but i keep getting the same error message over and over again.
It says that a capture device was not detected. I have tried Winfast PVR, VirtualDUB and some other capturing programs but all give the same error.
Am i doing something wrong here? I've installed the latest NVidia WDM Drivers on a clean windows 2000 as well as a windows xp system. Nothing but that same error?
Anybody else that can help me out here? Maybe i need to install some other driver i might have forgotten?
Please help me out, because otherwise i'll bring the card back to the shop.
I just purchased that same card and the manual states "To use WinFast My Vivo, you must first open MyVivo before running another media application with video-capturing capability. Any such application that is opened first takes charge of the input video; other applications cannot be used to display or capture the video input"
I hope this helps, let me know how it works, I want to try and use this for my captures if it does a decent job, did not want to have to buy an additional capture card. I haven't tried the card yet, got a bad mobo and had to send it back. -
The card only works with the software provided. Beside the WDM driver, you can capture with the Leadtek capture software. However, you can only capture in MPEG-1 & MPEG-2 format only and the capture quality is horrible(MPEG-1 even high bitrate).
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
leadtek PxDVR3200 H - HD component input
By Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 20:10 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 13:44 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
