How do I go about doing this and do you lose quality and if so how much.I am trying a 1 cd template but it seems my dvd player will only handle 29.76 framerate on a non standard vcd.
Thanx
You can use AviFrate to change the video framerate and CoolEdit or GoldWave to upsample audio then load audio and video separately into TMPGEnc using 29.970 fps template. You won't lose any quality this way but your audio and video will, most likely, playback too fast making it look funny. You can still try and see if that is the case - please post your results then.
even better would be to just use a utility like pulldown.exe to give you an internal 29.97 so your standalone will play it.
go here for pulldown.exe
http://www.doom9.org/index.html?/software2.htm
unzip it and open a cmd window then navigate to the path you have it stored in. Drag your mpv file into the command window and then do it again changing the extension to m2v so it looks like this:
d:\pulldown.exe d:\yourpath\yourmovie.mpv d:\yourpath\yourmovie.m2v
press enter and wait about 5-10 minutes for your video to have it applied and mux as normal -
pulldows only works on mpeg-2 so that's not it.
Unfortunatly the easiers was is just to modify the 1-cd template and make it's framerate 29.97. That's about the bast you can do and their will be problems.
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 09:05 -
Remove pulldown? (29.97 -> 23.976)
By Asterra in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2010, 19:12 -
Is SD 720x480 AVC (h264) with 23.976 framerate compatible with Blu Ray?
By hinsdale1 in forum Authoring (Blu-ray)Replies: 17Last Post: 11th Dec 2009, 10:26 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 17:57 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:29
